305-350... deleting the ECM
Old Feb 19, 2004 | 07:55 PM
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
how do i go about re-wiring the guages. i tried searching the board, and found nothing on it. I'm trying to figure out what i do about my gauges... speedo, tach, engine gauges, everything. I'm puttin gin a carb 350 where a 305 with comp. controlled carb used to be. I don't need the ECM, so i want to delete it.... but what do i do with my gauges?
Old Feb 20, 2004 | 04:53 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Plug them back in to the senders ?
The gauges & ECM are unrelated in operation (any year).
The oil and temp sender wiring lead to the bulkhead connector on the drivers side firewall next to the brake booster.
Buy some new senders, put them in the 350 and plug them back up. The gauges will work fine.
Old Feb 20, 2004 | 11:26 PM
Car: 1982 Trans Am
Engine: 383 chevy
since i have an HEI Dist, I run the tach to it, right? and the speedo is gear driven in an 82, so i dont need to worry about it, either, huh?
Old Feb 21, 2004 | 12:56 AM
deadbird's Avatar
Engine: TPI 305/ v6
You are correct. The tach, on all years as well, reads from the coil (generally a white wire for every GM made). And yes, the speedo will operate as usual.
Old Feb 21, 2004 | 06:08 PM
Car: 1982 Trans Am
Engine: 383 chevy
on the waterneck, there are two little plugs sticking out. i assume one is the temp sender... what could the other be?
Old Feb 21, 2004 | 06:50 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
temp sender is on the drivers side head, should be in the front hole... fan switch temp switch is on the pass side head.
the ones on the thermo houseing you dont need to plug back in, one is a sensor for engine coolant temp for the computer, the other im not sure...
when i did my swap, both in the 91 and the 86, i just put a normal thermo houing on there and got rid of the senders..
Edit: your going to need a manual switch or auto fan switch kit - the comptuer was responsible for controlling the fans. i tested this in my 91 firebird, when i had the sender out, to see if i needed it, i turned on the ignition and used a torch to slowly heat up the sending unit... fans never came on- so u will need a switch unless u have a/c which in that case you just turn on the a/c and the fans come on! you could also wire them to be on all the time, but thats a bit hack for me
Old Feb 21, 2004 | 09:00 PM
deadbird's Avatar
Engine: TPI 305/ v6
Not on a q-jet application. 99% of them had a mech (belt driven/old school) fan.
'82, on an f-body, never saw the light of an elec. fan to my knowledge.
IIRC, the other fitting on the thermo housing was a temp vacuum switch for the EVAP canister. Swaping out to a new or pre-emission waterneck would be a cleaner option.
Old Feb 21, 2004 | 11:09 PM
Car: 1982 Trans Am
Engine: 383 chevy
thanks for the help. I'll go get the new sender. anyone have a pick of it so i can put it in the right hole? (putting hair around it wouldn't help.....)
Old Feb 22, 2004 | 03:50 PM
fb305svs's Avatar
yeah my bad.... btw tho, converting to an electric fan can gain ya up to 8 hp on the top end
the sender is litterally supposed to be on the forward most large hol between #1 and #3 clinders... can't miss it!
Old Feb 22, 2004 | 07:31 PM
Car: 1982 Trans Am
Engine: 383 chevy
makes sense. I'll look into converting to an electric fan... especially an IROC twin fan setup. for now, I'm just trying to assemblw all my parts into a car. thanks for the help; I'll be prepping the motor tomorrow for the install.
Old Feb 22, 2004 | 10:37 PM
fb305svs's Avatar
sounds like fun! good luck with it!
Old Feb 25, 2004 | 06:41 PM
Kontrax's Avatar
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
i had a q-jett with electric fans, guess im odd huh? ive also done the 350 swap into my 86 and tossed everything. i was going to run all aftermarket guages but i guess i can keep the stock guages now after reading this post. going to be fun chasing all those wires. its weird because half my dash is digital and have is mechanical...how the hell does that work?
Old Feb 25, 2004 | 07:30 PM
deadbird's Avatar
Engine: TPI 305/ v6
Don't quote me but, as far as I remember, just the l69 305's (H.O.'s) came with elec. fans. I'm not sure but possibly the last years of the lg4's (which I think was '87) too. I'm not too big on motor option history. Not extremely common to have a q-jet and elec fan but, a small amount had them. As far as the cluster... you're on your own.. I've yet to come across a complete elec. dash in the junkyards here. There was one but, it was trashed beyond seeing anything.
As far as gauge wiring, the temp gauge is a single solid green wire that goes to the bulkhead and the oil press sender have a tab/black (or maybe just tan) wire.
Both go direct to the bulkhead fron the sender though so luckily, it's not a huge pain to trace them.
Night rider327
Oct 9, 2015 09:25 AM
djmarch
Oct 2, 2015 10:41 PM
Zell1luk
Sep 29, 2015 10:36 AM
