HEI distributor questions
Old Feb 19, 2004 | 07:57 PM
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
I have a GM performance HEI with a 50,000 volt coil. do i need to wire this so anything else, like say, an MSD blaster 2? or do i just wire it up to my ignition switch and to the battery? I have no idea what to do.
Old Feb 22, 2004 | 12:37 PM
noc_81's Avatar
I always had a HEI in mine, so I just reused the old harness there are two small (2wire?) connectors and one big (4wire?) plugs that go into my distributor.
From the depths of my memory, I believe there would be an ECM connector if you haven't pulled the ECM yet, a wire connecting the cap to the distributor, a tach cable, and the power source cable.
With an aftermarket or performance ignition, you would do well to purchase a good quality distributor harness, since you can't take advantage of a good coil without good wiring.
Old Feb 22, 2004 | 07:34 PM
Car: 1982 Trans Am
Engine: 383 chevy
DUDE!!!! YOU HAVE MY CAR!!!!! SWEET!!! ok, I'm better now. I found one two-wire connectr that looks like it's the one I need for the tach. there's on cable going from the distributor to the cap, and then a plug that (I assume) is for the connector to the tach. I guess i just need to find where to get power?? since it IS an aftermarket (sorta) HEI, where do i get the harness to wire it up? I'm ditching the ecm, so all i need is a power source and a tach.
Old Feb 24, 2004 | 08:52 AM
Car: 1982 Trans Am
Engine: 383 chevy
found what i think to be the tach wire. now where do it put power to it?i don't see a plug or connector anywhere for it.
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Jan 29, 2017 07:00 PM
stalkier
Aug 21, 2015 01:54 AM
midias
Aug 15, 2015 05:07 PM
stalkier
Aug 7, 2015 04:49 AM
