coolant fan and other woes
Old Mar 1, 2004 | 08:27 PM
MFaulkner's Avatar
Car: 90 Formula
Engine: 305 TBI
Today I discovered that my coolant fan didn't come on. After checking the fan relay, it appears that its 12v+ (big wire that used to be on whenever the ignition was on) is no longer giving 12v. I checked a wiring diagram, which says there's a fusible link on that wire, but where exactly is it? What does it look like? I'm fairly confident the fusible link is the problem (I'm pretty sure I shorted it out yesterday, trying to fix another problem - )
Next on the list, my temp. guage hasn't been working for the last few days. WINALDL shows a coolant temperature reading. That reading is from the sensor on the intake manifold by the thermostat; does the guage use that sensor? Any thoughts on what could cause a temp guage to stop working?
As you can imagine, I won't drive the car while it has a faulty cooling system AND no way for me to know what the temp is while driving, so thanks a ton to anyone who can give me some quick advice!
Old Mar 1, 2004 | 11:12 PM
84 Z28 5.0 HO's Avatar
Car: 84 Camaro Z28
Engine: 305 L69
the coolent sender for the computer is in the water neck. The coolent temp sender for the gauge is a small plug like thing with only one wire, it is by the number 1 spark plug
Old Mar 4, 2004 | 09:40 PM
MFaulkner's Avatar
Car: 90 Formula
Engine: 305 TBI
Thanks! I checked the sender by the spark plug, it looks like its in pretty bad shape. I guess it's the culprit. Hopefully it ( and a bunch of other things) will get replaced this weekend.
Old Mar 4, 2004 | 11:27 PM
Car: 84 Camaro Z28
Engine: 305 L69
there are 2 plugs one on the driver side head, this is the one for the guage. Then there is one on the passanger side head, this is for the fan.
Old Mar 5, 2004 | 12:08 AM
83_1/2 L69's Avatar
Car: 83 Z-28 (Original owner)
Engine: 305 CC-carb
Transmission: Richmond 6-speed, Rear:3.73
Re: coolant fan and other woes
I think all the fusible links are fed from the starter + cable connection.
sheachopper
Jul 31, 2019 11:27 AM
Fanatic1074
Oct 2, 2015 03:47 PM
