Need help quick
Old Mar 22, 2004 | 08:37 AM
91zconvt's Avatar
Car: 87 Iroc
Need help quick
Ok, while installing my 4th gen dash, I accidently touched the power wire (red) where it plugs into the headlight switch, to another wire and it prety much sparked and now I have no headlights or gauge lights. The car has no interior right now because of the swap, and I don't know what else works or doesn't, but I don't think there's any power to the HVAC. I was told earlier to check the fusable links at the starter, and I did, with a test light, and all checked out fine. Power before and after the fuses. So, can anyone reccomend anywhere else where there may be a fuse that I can check? I really need to get the car back together.
Old Mar 23, 2004 | 09:13 PM
tstokka's Avatar
Car: 2- 1986 TA 1 t-top 1 hardtop
Engine: 305s
Transmission: autos
do you have power at the light switch?
Old Mar 23, 2004 | 09:26 PM
91zconvt's Avatar
Car: 87 Iroc
No, I didn't, or at the accessory fuse for that matter.
For a quick fix, here's what I did. please tell me if this is safe or not.
I ran a 16 gauge wire from the battery and splice it to the wire going to the accessories fuse. I put a 18 gauge fusable link inside the car, right before it splices into the wire going to the accessories fuse. Everything works fine now, and I've driven it for 2 days with no problems.
I've tried everything I could hink of that could cause a problem with doing that; touched wires together from the headlight switch, etc. and everytime, it just blew the accessories fuse.
Old Mar 23, 2004 | 11:54 PM
White91GTA's Avatar
Car: 1991 Trans AM GTA
Engine: 5.7L TPI
if you didn't do it to begin with...the smart thing to have done would have been to disconnect the battery.
F-body-fan
Jan 12, 2023 01:49 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
3.8TransAM
Sep 27, 2015 08:37 PM
