okay i hear our o2s arent the fasest thing but....
Old Mar 27, 2004 | 06:27 PM
tbfirebird's Avatar
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
okay im thinking about getting an o2 gauge but i hear that its not worth it with our sensor cuz there to slow is this true.also how do i hook it up did a search but nobody is really clear on what to do.thanks in advance.
Old Mar 28, 2004 | 08:51 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
An a/f guauge will work just fine with you o2. You just splice a wire from the o2. The only problem with the gauge is it wont be very accurated because we dont have a wideband o2 in our car.
Old Mar 28, 2004 | 05:47 PM
83_1/2 L69's Avatar
Car: 83 Z-28 (Original owner)
Engine: 305 CC-carb
Transmission: Richmond 6-speed, Rear:3.73
Our cars use the same type of zirconium dioxide O2 sensor that is used in most cars. It is a “narrow band” sensor that works fast enough. The problem with them is that the signal output is “non-linear” with respect to A:F. They are really only good for telling you if the A:F is RICHER then 14.7 to 1 or LEANER then 14.7 to 1. The correct name for those cheap A:F gauges is “rich/lean gauge”
The slow cycling from rich to lean and back is caused by the slow speed of the ECMs in our cars as they are actually controlling the A:F in closed loop mode.
There are a few “lean burn engine” cars on the road and some very expensive aftermarket fuel injection computers that use a more complex “Wide Band” O2 sensor (UEGO) that can correctly detect A:F from 10 to1 all the way up past 20 to 1.
There are also aftermarket wide band gauges that come with an extra, wide band sensor that you install in another exhaust bung. They cost a few hundred dollars.
Fronzizzle
Mar 18, 2019 08:29 PM
firebirdta84
Interior Parts Wanted
Aug 30, 2015 09:28 PM
Jae992
Aug 27, 2015 09:07 AM
db057
Aug 22, 2015 08:17 PM
Bob88GTA
Aug 18, 2015 03:31 PM
