Dist. External Coil Question
Old Mar 31, 2004 | 03:32 AM
jrod's Avatar
Car: 87 Camaro
Engine: 305 4 BBL
Hi folks,
Can someone tell me how many wires go into a remote coil ?
There are two female recepticals on the coil and two female recepticals on the distributor. Are any of these ports not used, or am I missing some wires?
1987 305 4 bbl
Thanks in advance for any help !!!
John R
Old Mar 31, 2004 | 06:23 PM
redrummer's Avatar
Car: '88 Trans Am GTA
Engine: 5.7L L98
Axle/Gears: 3.27 Aussie 9 Bolt
You're missing wires.
There's a grey connector on the wiring harness on the passenger side that plugs into the coil. There's also a wire with a black connector that plugs into the coil with a two prong plug on the other end that plugs into the distributor. There should also be another black four prong plug that plugs into the distributor coming out of (I think), the wiring harness that goes across the back of the engine.
Old Mar 31, 2004 | 10:15 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Yup, all are used. And the two that fit on the coil interlock. One(I don't remember which) has to go on first.
Old Apr 1, 2004 | 03:35 AM
jrod's Avatar
Car: 87 Camaro
Engine: 305 4 BBL
Thanks guys, now the search begins !
John R
Old Apr 2, 2004 | 07:33 AM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
Dist sends the C terminal pulse to the coil on pin A of the black connector (nearest to edge of coil) to charge it. Coil sends 12V to dist on pin B of the black connector. Grey connector A sends the tach signal to the dash cluster (and is connected to black A inside the coil) and Grey B gets switched 12V from the fuse panel (and is connected inside the coil to black B). HTH!
apo_bailon15
Mar 28, 2016 05:20 AM
db057
Aug 22, 2015 08:17 PM
redmaroz
Aug 16, 2015 11:40 PM
midias
Aug 15, 2015 05:07 PM
L98GTA87
Aug 5, 2015 11:02 PM
