Fan staying on
Car: Firebird
Fan staying on
The fan behind the radiator stays on all the time my friend says thats not normal and I should fix that but I dont know whats causing it to stay on.
Car: 1987 Camaro IROC-Z
Engine: L98 bored .40 (357 ci)
Transmission: Race Ready 700R4
Axle/Gears: 9 bolt 3.70 posi
Sounds like someone has your fan wired direct to the ignition...my brother did with his 84' Z28 because he was to cheap and lazy to fix the problem correctly....
Car: 04 Xtreme Blazer
Engine: 4.3L V6
True true... that is actually what I am going to do when I get myself a 12v relay... going to run +12V through a lighted switch inside my car to a +12V relay, when energized , the other side of this relay will pull the fan switch wire (I think it's a green or green/white wire going to the fan relay) to ground.... which I hope will turn on the fan at my leisure
