Difference Between Hei And Non'
Old Apr 7, 2004 | 06:03 PM
87 BlUEROC's Avatar
Car: 87 IROC Z
I have an 87 IROCZ 5.7TPI, I have to replace my distributor and want to know what the diff. was between HEI and Non-HEI? I know my coil is mounted off to the left with a coil wire going into the cap. What would be the best distributor to get with a highly modified car? Any help on this would be great, I can give more specifics on the mods if needed.
Old Apr 7, 2004 | 06:17 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
There hasn't been a non-HEI distributor in a GM car since 1974.
Old Apr 7, 2004 | 07:13 PM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
an aftermarket hei relacement is fine till you get into NOS and or high revs. the hei starts to break down at high revs and its good to have the adjustablity of a ign box w/NOS. so if you want to go that route i would suggest an MSD box, high output coil, and a billit alum. relacement distributer.
i just noticed you have tpi, i dont know how these things will work with fuel injection
Old Apr 7, 2004 | 09:16 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
But for the purpose of searching for and purchasing ignition products for our cars today, separate coil modules are designated HEI, and coils in the distributor cap are non-HEI.
So to answer your question, for purchasing aftermarket caps, wires, etc., yours is HEI. If you're looking for plug wires, you might have to look for products for 88+ models. For replacement distributor caps and coils, MSD and Hypertech make them, probably other companies too.
Old Apr 7, 2004 | 09:53 PM
87 BlUEROC's Avatar
Car: 87 IROC Z
Appreciate the help fellas, I am gonna go with the MSD set up, I am understanding the HEI setup now, just want to make sure before I spend all my money that I am getting the right stuff. I put a new Cap and Rotor and coil on a few years back, but with oil in my distributor, it is time for an upgrade
Thanks.
86CamaroDan
Sep 29, 2015 10:08 PM
BAMiller
Sep 14, 2015 06:38 PM
Numbah-1
Sep 12, 2015 08:57 PM
J.C. Denton
Sep 8, 2015 05:35 PM
greenyone
Sep 2, 2015 03:39 PM
