T-5 conversion
Old Apr 20, 2004 | 06:31 AM
87project2.8's Avatar
Car: 87 Camaro
Engine: 2.8L V6
T-5 conversion
Working on a 700-r4 to T-5 conversion and I've run into another snag. The 700r4 shifter had 2 cables running to it. One of them was the actual shift cable. That one is gone now. The other runs from the shifter to the steering column. I don't know what this is, what it does, and/or how to get rid of it. What is it, can I get rid of it, and do I need to bypass it somehow?
Jeremy
Old Apr 21, 2004 | 05:16 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
It's the cable for the shifter lockout when the car is off. It leads to the ignition switch. You should be able to remove the cable from the switch or, you can go buy a replacement ignition switch for a standard shift at autozone for like $12-14.
Linson
Oct 24, 2025 02:00 PM
2012sergen11
Oct 13, 2015 07:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
mfp189
Sep 27, 2015 09:25 AM
