in need of wiring diagram
Old May 11, 2004 | 04:19 PM
89 305 Formula's Avatar
I need a wiring diagram of the cooling system/fan setup. I need to put a switch on my fan because it doesnt like to run all the time when it needs to. I was driving yesterday and the fan was not on in traffic and my car ran to about 240-250 degrees, i had to keep shutting it off to try to cool it down. if anyone has a diagram of this for me please let me know.
Old May 13, 2004 | 10:13 AM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Look down on the passenger side front frame rail, see the AC aluminum line from condensor? Small switch on this. This switch may be normal open or closed. Connect the two wires to a dash switch and you can control fan or fans using factory relays, if they are working.
Also some diagrams here. http://www.fl-thirdgen.org/wiringdiagram.html
Old May 13, 2004 | 11:06 AM
dr1's Avatar
dr1
Car: '89 Firebird Formula
Engine: 305 TBI
just for future refrence, while your preventing some damage by running the engine while its that hot, shutting your engine down for short periods of time only makes the engine hotter.. you stop all flow of water through the engine
you may notice when you park your car while the temp is right at its normal spot, and come back like 10 mins later its actually hotter..
anyways that wire runs all the way up to a relay right near the brake booster, tap into that wire to the switch, and run the other side of the switch to a ground.. i believe the wire is green with a black stripe
i dunno im feeling lazy right now, do a search, theres a million posts on this subject
89GTAOz
May 16, 2020 09:31 AM
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
