Not getting power to starter Solenoid.Help
Old May 17, 2004 | 09:18 PM
mhaskell's Avatar
Ok so turn the key, fuel pump comes on, all lights etc are fine. Engine doesnt crank however.
If i jump the main power feed to the starter over to the small solenoid it turns over instantly.
I'm thinking it is a fusible link or ignition switch? Are there any relays to check?
1989 5.0 TBI by the way.
Old May 17, 2004 | 10:04 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello mhaskell,
I have just replied to your first post on this subject. It helps if you would limit your threads on a particular matter to one forum instead of posting the same one in multiple forums. You will get better responses to your problem this way.
BRoss99
Aug 10, 2025 05:08 PM
5spdcamaro
Aug 28, 2015 02:12 AM
L98GTA87
Aug 25, 2015 02:23 PM
sailtexas186548
Aug 24, 2015 10:11 PM
Accerrito22
Aug 23, 2015 07:22 PM
