Manual fan switch
Old May 23, 2004 | 01:02 AM
CogsRS's Avatar
Car: 87 Monte Carlo SS
Transmission: 200 4R
Manual fan switch
My fan doesn't go on by itself, so for the past year or so I've been switching it on by turning the A/C on. I've been wanting to put a switch in for a long time, but last time I tried the wire melted. I think it was too small. What would be a good guage wired to do this? Would 14 be enough or 12? I have both. I can go get some 10 if I need to. Also, where can I ground the switch? The switch will be in the console next to the radio. The closest bolt that goes into the body of the car is for the shifter. Would that be okay to ground it there? I dont know much about grounds, so I'll need some help there. Thanks.
Old May 23, 2004 | 03:31 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
My switch is not grounded. I have a fusible link with a 30 amp fuse between the switch and the battery.
Old May 23, 2004 | 09:33 AM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
since the fan comes on with the A/C, all you need to do is ground that same wire(green IIRC) off the relay through a switch, don't need big wire 16 or 14 would be plenty, any part of the body will work good
Old May 26, 2004 | 11:17 PM
3gc's Avatar
3gc
Car: Z28
Yep, it's the green one. I tried wiring it the same way it sounds you had it wired and the switch got too hot so i did it the correct way with the relays and everything works fine.
89GTAOz
May 16, 2020 09:31 AM
krisner89
Oct 10, 2015 06:03 AM
bryanwood74
Sep 24, 2015 09:50 PM
Ducati900ss
Sep 2, 2015 09:05 AM
TA8487
Aug 16, 2015 12:21 PM
