Headlights are messed up!!
Old May 23, 2004 | 01:05 AM
CogsRS's Avatar
Car: 87 Monte Carlo SS
Transmission: 200 4R
Okay, here's my problem. When I turn the low beams on only the left side comes on. When I turn the brights on the other 3 come on including the right side low beam and the left low beam shuts off. Whats the deal? Why doesnt the right low beam come on on low and why doesnt the left low beam come on on high?
Old May 23, 2004 | 04:30 PM
Vader's Avatar
Remove, clean, reattach, and verify all your headlamp grounds. I'm guessing that will solve it.
Old May 23, 2004 | 05:35 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Maybe they are burned out?
Old May 23, 2004 | 09:46 PM
CogsRS's Avatar
Not burned out. They all work, just at different times which is mostly the wrong time. All connections are clean.
Old May 23, 2004 | 10:54 PM
There are two filaments in the outboard hi-low bulbs. One filament in each bulb has burnt out.
F-body-fan
Jan 12, 2023 01:49 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
