what the???
Old May 25, 2004 | 02:58 PM
4monkeys's Avatar
Car: 89 rs
Engine: 305 tbi
Transmission: 5 spd.
what the???
I NEED HELP. I HAV EAN 89 RS W/305TBI W 5SPD. AND IT HAS A PROBLEM. WHEN STARTING THE CAR THE TBI GETS NO GAS, IF YOU PRIME IT( DUMP A LITTLE GAS IN IT) IT WILL START AND THE INJECTORS WILL WORK ONLY WHEN THE THROTTLE IS MOVING. THE WILL NOT MANTAIN AN IDLE OR ANYTHING.
I HAVE REPLACED THE I.A.C,TPS,DIST. ENGINE WIRE HARNESS AS WELL AS THE BRAIN. I HAVE HAD IT SCANNED AND THE ONLY THING THAT POPPED UP WAS FOR THE SECURITY SYSTEM. AND THE ONLY CODE I GET IS 53. I CAN NOT FIND A SORT ANYWHERE. I HAVE ALSO HAD THE FUEL PUMP CHECKED AND IT'S ALL GOOD. THE CAR STARTED THE OTHERDAY AND HAS NOT STARTED SENSE.
PLEASE HELP I'M OUT OF IDEAS.
Old May 25, 2004 | 11:44 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello 4Monkeys,
Please do not post multiple threads on the same subject matter throughout the board. This can get confusing and takes up server space. Your previous post on this subject in this forum has been responded to.
