Headlights suck
Old Jun 16, 2004 | 11:21 AM
92_Z28_convt.'s Avatar
Car: 1992 Z28 Convertible
Headlights suck
I was wondering if i just happened upon some crappy headlights or what but instead of being able to see a wide view of the road in front of me, its like the headlights shoot out two straight beams and i cant see a damn thing (they point like a laser rather than spread)...does anyone else have this problem and if so how can i fix it?
Old Jun 16, 2004 | 03:35 PM
ThraxXx's Avatar
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
meh, your not the only one with that issue. My headlights do the same thing. They are useless on back roads that are dim litted. I fixed that issue by getting some Blazer tech foglights. They were bright however after I did the 100watt conversion they became stupid bright and did a better job then the headlights ever could do.
Old Jun 20, 2004 | 09:18 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: Headlights suck
Have you tried a set of silverstars?
Old Jun 21, 2004 | 12:12 AM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
you dont mean those blue ones do you?
Old Jun 21, 2004 | 12:29 AM
Noooo...silverstars are the bright white ones. They make a huge difference than stock headlights. I love them. They are not cheap however. They run anywhere from 18 to 25 dollars each. Try the low beams first. If you dont like them take them back.
Old Jun 21, 2004 | 08:14 AM
silverstars
I went and got some the other day i just havent found the time to install them yet.
3.8TransAM
Oct 1, 2015 07:47 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
