WTF? Tach Stays Pinned
Old Jun 25, 2004 | 08:25 PM
Max's Avatar
Max
Car: '89 Camaro Convertible
Engine: LB9 Heads/LT1 Cam Holley 670 Carb
Transmission: T5 Manual
My factory tach stays pinned at 7000 at all times. Even when the ignition is turned off.
Any ideas?
Old Jun 26, 2004 | 12:21 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
https://www.thirdgen.org/techbb2/sho...+needle+finger
Old Jun 26, 2004 | 01:38 PM
Max's Avatar
Max
First, thanks for the advice. I may end up trying this technique.
I'm not sure my problem is the same as that described in the link you provided. My tach stays pinned at all times, whether the car is on or off. Also, the problem began after I cut some wires under the pass. side dash (trying to remove the ecm harness). Could this be an electrical problem?
sheachopper
Jul 31, 2019 11:27 AM
lewandom
Oct 1, 2015 08:15 AM
Eric-86sc
Sep 28, 2015 11:37 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
