Gauge Cluster going nuts
Old Jul 12, 2004 | 09:35 AM
IroczInOz's Avatar
Couple days ago the cluster went nuts buzzing turning off and on etc. I did not however lose my headlights, I was driving at night. The gauges bounced up and down liek crazy then it settled then again etc. Not sure maybe a bad ground? When the indicator was on I could see the RPM needle pulsate with the blinking.
What should I be looking for a bad ground?
I found the diagrams trickster posted will help
Old Jul 12, 2004 | 10:12 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hey IroczInOz,
There should be two grounds near the steering column for the instrument cluster. They will be attached to the forward dash support frame. Let me know if you need any more info.
Old Jul 12, 2004 | 11:17 AM
IroczInOz's Avatar
Forward dash support frame? If I can't find them I will try and trace the wires from the connectors going by the diagram
Old Jul 12, 2004 | 11:24 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The metal frame piece above your knees that the dash bolts to.
Old Jul 12, 2004 | 11:26 AM
IroczInOz's Avatar
Cool got it will check it out any dramas will get back to you.
Thanks,
Mike
gixxer92
Apr 12, 2022 12:09 AM
codeysabatini
Sep 20, 2015 11:36 AM
CatmanFS
Sep 19, 2015 09:00 AM
Trevor Tarry
Sep 15, 2015 02:04 AM
TrevinE
Sep 14, 2015 03:20 PM
