Mag Pickup Question
Car: 68 Camaro
Engine: Original 327 .040 over 89 TPI system
Transmission: M20
Mag Pickup Question
I am in installing an Accel 300+ ignition box into my 68 camaro equipped with an 89 TPI system.
Searching the message boards I've found a wiring diagram on the following thread outlining the install.
https://www.thirdgen.org/techbb2/sho...accel+ignition
On the diagram it refers to Mag pickup+ and Mag pickup-
Where exactly do I find these wires, underneath the distributor cap? or can I splice into them via the 4 pin distributor connector?
As always, any help is greatly appreciated.
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It is on the distributor shaft underneath the poles, the two wires plug into the ignition module. It is more commonly called the Pick-Up Coil.
Chuck84TA
Jul 15, 2016 09:05 PM
