Headlight conversion PNs
Old Jul 27, 2004 | 10:54 AM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
I did a search okay you search *****!!!
I am really only looking for PNs to the stuff some of you are using. I found a few of you are pleased with the Hella headlight housings for the H4 "HID" conversion. I have already made a wiring harness using 10 AWG wires and a pari of 30amp relays. That makes my stock lighting better, but I want more!! THrough searching here and on the web I have found a bunch of companies that make conversion kits. I just want the headlight housing of HIGH quaility and then some bulb part numbers. The rest I think I can handle, it terms of modifing wiring or whatever. BTW, for those that are using new low beams, what do you think of the light quality?
THanks ya'll...
Linson
Oct 24, 2025 02:00 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
