Really Messed Up
Old Aug 2, 2004 | 09:56 PM
5.8L Camaro's Avatar
Car: 1988 Camaro
Engine: 350 V-Eight
Really Messed Up
I was setting the timing on my car, and I forgot to plug the power wire back into the distributor, and left it touching the valve cover. When I went to turn the car on it made a sparking noise by the starter, then smoke came out from the starter. After that half of my electrical system wouldnt work(starter, rear hatch, radio, gauges, windows, door locks) My friend said I might have blown a fusible link, by the starter. I had no idea what that was, so I got under the car and pushed up on all the wires to the starter. Once I did that everything worked again. I had my fuel pump wired into a wire, and now that wire no longer has power to it. The alarm that goes off when you leave your lights now goes off whenever the lights are on, even when the car is running. My initial timing isnt set so when the rpms start to jump around and the engine misses the radio will die out then turn right back on. The gauge fuse blew out. What the heck happend? How do I fix this?
Old Aug 3, 2004 | 02:22 PM
Car: 1988 Camaro
Engine: 350 V-Eight
So is everyone else as lost as me?
Old Aug 3, 2004 | 06:48 PM
craashmann's Avatar
Car: 1991 Camaro Z28
/shrug good luck
Old Aug 10, 2004 | 03:50 PM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
I had a similar problem with my 81 cutlass although i didnt actually ever short anything while working on it. It lost all power one day to the dash, locks, radio, interior lights,starter everything. it ended up being a shorted wire that ran from the positive terminal on the battery to the starter. this wire then in turn supplies power to the whole car. This wire being the main positive wire for the whole car may have become shorted when the you grounded the wire from the distributer when you moved it it made a conection but not a good enough one. Just a thought hope its helpfull.
F-body-fan
Jan 12, 2023 01:49 PM
Ed1LE
Sep 30, 2018 09:14 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
mrbird
Oct 20, 2015 03:43 AM
