Distributor
Car: 84Z & Porsche
Engine: 427sbc - 471 - 850 Demon Claw
Transmission: Bowtie stage II TH700R4 - 10" 3000
Axle/Gears: 9 Bolt w/ 3:45's
Distributor
I'm in the process of ditching my 305 and adding a high hp motor...Question? What is the best distributor? I'm quite in a quandry between an HEI (W/ Vaccume adv.) or Mallory electronic (this is pointless). Or what does one suggest? I have heard that the vaccume advance models with mechanical advance also are a must...but will ask advice on which is the best....the Motor is going the be a crate GM P/N12498772 ZZ383/425...ditch the manafold and add a Holley 477 blower set-up....any suggestions on the correct distributor??? thanks, Cocacolakidd.
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
personally id go with a modified stock 75-79 years HEI with a 454 module, you can pick out the best weights and springs somehow im not sure how, you have to be able to measure advance at certain RPMs and know what is best for the engine, and swap springs and weights til its advancing in correct time for the engine
you can get performance pickup coil and ignition coil too for these.,
use google.com to find out all this
good luck
good luck
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Damon
Sep 26, 2015 04:29 PM
