will gauges work with a carb swap
Old Aug 16, 2004 | 05:38 PM
blowntransam's Avatar
I have a 86 tpi transam and im about to put a carbed 350 in it will i need to leave any wires hooked up or leave the computer cause i still want my headlights and cruise and all that other stuff to work.
Old Aug 16, 2004 | 05:46 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
those items...(gauges, lights,cruise) were all on independent harnesses in my 85..everything worked after I removed the computer, except the fuel pump..had to power that up with a relay and a key on pwr
Old Aug 16, 2004 | 05:52 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Gauges, headlights, etc. have nothing to do with the computer.
Old Aug 16, 2004 | 07:01 PM
where is the computer located
Old Aug 17, 2004 | 12:36 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
In the passenger side of the dash, below the speaker.
There will be a plastic yellow box attached to the computer case - do not remove it (the yellow box), or your speedo will not work. Leave it hooked up except for the brown wires; those go to the computer.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
justin57
Aug 20, 2015 07:05 PM
86IROC112
Aug 17, 2015 02:00 PM
