Where are both fan solenoids?
Old Aug 26, 2004 | 12:33 PM
REALPOWER's Avatar
Car: 1984 Camaro on steroids/ 1987 iroc-z28 5 speed.
Engine: 383 nitrous motor / poindexter 305
Transmission: Th350
I have and IROC with dual fans. The 238* switch works, but the fans don't kick on until then. I have a toggle switch hooked up right now, but I want to wire it the way it was. It appears that I only have 1 solenoid that runs both fans. This is located next to the battery. Where is the other one?
Old Aug 26, 2004 | 05:45 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
What year do you have? One should be on the fender well by the battery and the second one should be mounted behind the right hand headlight by the radiator.
Old Aug 27, 2004 | 07:21 AM
REALPOWER's Avatar
Transmission: Th350
It is an 87, could you draw me a little diagram of where they are under the hood? I have seent the battery on both sides. Mine is on the passenger side.
Old Aug 27, 2004 | 01:46 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Yep, here it is!!!!!!!!!!
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
BrianI
Oct 3, 2015 12:57 PM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
