Power lock doors help
Old Sep 7, 2004 | 05:13 PM
cIaRmOaCrZo28's Avatar
Car: 1989 Iroc-Z Camaro
Engine: 5.7 liter 350
More specifically, I am trying to install keyless entry into my 89 camaro. First thing I need to do is to decide what type of locking system I have. I see 3 wires, black, orange and light blue. Now I need to figure out what each of these wires does. I do not have a multimeter or other test device to use, so I'm hoping someone on here will know what each wire does.
There are 8 types of locks they have listed
A:(+) 12V pulses from the switch to the factory relays
B:(-) pulses from the switch to the factory relays
C:reversing polarity
D:aftermarket actuators
E:mercedes-benz and audi
F:one-wire system
G:posetive (+) multiplex
H:negative (-) multiplex
I think it should probably be a or b, but am not sure which...or it might be a multiplex system =( i dunno
Old Sep 7, 2004 | 07:29 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
There are more wires than that, what you are seeing is just the wires to the switch. Maybe this will help you some.
Old Sep 7, 2004 | 07:30 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
page 2
Old Sep 8, 2004 | 10:22 PM
before u replied i thought this was gonna be simple...thanks a lot!
=) heh, sorry...i really am gratefull for info.....I haven't really had a chance to look in the car too much. I looked with door panels off...then followed the taped up wires to the fuse box (fuse box is under passenger side of dash right? please correct if I am mistaken) but I didnt cut the tape so I'm not posetive that those r the 3 I think they are going into it...
after looking at the install manual I thought things would be pretty easy if I can figure out for sure what kind of door locks these fit under...but now I'm thinking I'm going to either need a multimeter, need to call the producer to try and get more vehicle specific info, or go to an actual install place (last resort)
first thing I need to do when I get a lil more free time is look at all the wiring and identify each of these wires as the ones on the page u sent me..the biggest problem is going to be finding where each of these things are.
switches, duh...door lock relay assembly..no clue...lock motors? are these the actuators inside the doors? if so I cleaned and rehocked those up to the metal things to get them to work...so I know where those are...fuse block..is that whats under passenger side dash, or is that the cpu?
sorry for stupid questions, i really am trying to learn....thanks again for help....lol i dont even wanna know what I woulda ended up trying without it.....we'll just say itd b bad
Old Sep 8, 2004 | 10:57 PM
cyipher's Avatar
Car: 1984 Pontiac Trans Am
Engine: 305 SBC
Transmission: Automatic
Wouldnt this be reversing polarity?
Old Sep 8, 2004 | 11:35 PM
probably...i bought the keyless entry thing online...and i dont think it has a complete install manual..so I'm gonna try and get my hands on that...i dont have anything explaining what the specific types are in depth...i dont wanna screw somethin up doin it wrong..just got my locks workin again
if anyone wants to check it out,
http://www.corecapacity.com/Print1041.pdf
is the pdf file...ill be reading and re-reading that..just printed it out, but someone who actually knows what these things mean might be able to help a lil
Old Sep 8, 2004 | 11:37 PM
actually after re readin that a few times im gonna say ur probably right...by the way it says that it sends one voltage and the other ground
__________________________________
ok, found some helpfull files that I will upload...or type out by hand, i think its either reversing...or multiplex
Old Sep 8, 2004 | 11:44 PM
cyipher's Avatar
Engine: 305 SBC
this dosent say what type of system it is but i hope this helps
http://www.the12volt.com/request/8990camaro.asp
Old Sep 8, 2004 | 11:55 PM
oh oh oh, very cool =) printing....printing lots of junk so ill b ready when i actually start cutting wires and messing with things...tells me what all the wires r that ill b lookin at, thanks!
Old Sep 8, 2004 | 11:59 PM
cyipher's Avatar
Engine: 305 SBC
I tell you i can hook almost anything up but i dont know what the hell the factory was doing when designing some of these circuits.
Old Sep 9, 2004 | 12:03 AM
that sounds promising
heh o well...ill have lots of time to mess with this in the next week or so.......as long as i dont kill my car, ill b happy....but ill b way happier if i can push a button from outside...and my doors unlock
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
IrocBuzz
Camaros Wanted
Nov 20, 2015 11:29 AM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
