Wire to hook up a Laptop???
Old Sep 17, 2004 | 12:54 PM
marcolanz's Avatar
Car: 1985 IROC TPI
Hi guys! Is there a wire to hook up the car to my laptop? It is a PC. Also, i would need a program for the laptop as well! Thanks!
Old Sep 17, 2004 | 01:04 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: Wire to hook up a Laptop???
It's called an ALDL cable. YOu can either buy one or make one yourself...Do a search here and you will find how to make it.
Old Sep 17, 2004 | 09:48 PM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
There are a few programs you can use. FreeScan, Datamaster and WinALDL come to mind. I'm not sure if TunerPro supports your ECM yet.
For a cable there are many places. If you have a serial port on your laptop you have more options available to you. I only have USB and went nuts trying to find a USB-Serial adapter to go with my WOT cable... until I just ate the $65 and bought a Moates ALDL cable CABL1 and the APU1 adapter.
midge54
Dec 27, 2019 04:14 PM
Accerrito22
Aug 23, 2015 07:22 PM
CORV3TT3
Aug 23, 2015 11:26 AM
stalkier
Aug 7, 2015 04:49 AM
