interrior light fuse blowing
Old Sep 28, 2004 | 06:48 AM
curtis84ta's Avatar
Car: 1984 pontiac trans am
Engine: Block #14010209...350...80-85
Transmission: 700 R4
as the title says my interrior light fuse always blows after like 10 secs of having a new fuse in it will blow. any suggestions?
Old Sep 28, 2004 | 09:09 AM
-ZERO-'s Avatar
Car: 86 IROC-Z (daily driver) 87 IROC-Z (under construction)
Engine: 305 H.O.
Thats always a fun one to deal with! does the fuse blow when everything is turned off? ie: doors closed, dash lights are off, dome light is off.
Old Sep 28, 2004 | 11:35 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Check to see if there is anything in the cigarette lighter or a short at the cigarette lighter connection. That seems to be a favorite spot for that problem you are having.
Old Sep 29, 2004 | 06:48 AM
curtis84ta's Avatar
dont' know havn't checked ill check that tonight but now im getting feedback through my speakers when i either hit the breaks or turn on the signals i hear a lil clicking through the speakers would that be a ground somewhere?
Old Sep 29, 2004 | 07:19 AM
-ZERO-'s Avatar
Engine: 305 H.O.
Very possible. You might have a short somewhere behind your cluster. What to you think Trickster?
Old Sep 29, 2004 | 08:01 AM
LUVmy92's Avatar
Car: Camaro
Yeah what Trickster said. Mine kept blowing and I found a short in the wire on the cig lighter.
Old Sep 29, 2004 | 05:29 PM
curtis84ta's Avatar
ok i got the interrior lights working (my own fault) i didn't disconnect the stock wires from my deck (im running all mids off one amp now). and for some reason that was cutting them out i have no clue why so i capped off all the wires headunit and car side. BUT what still remains is that clicking sound when i use the signals. i reground everything. and it still clicks.
anyone know if its the dash thats doing this or not? anyone have/had similar problems
please help
Old Sep 29, 2004 | 06:05 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Are your speakers grounded or ungrounded?
Old Sep 29, 2004 | 06:34 PM
curtis84ta's Avatar
i have both + and - from the speakers connected to the amps if thats what you mean and the amp is grounded.
Old Oct 11, 2004 | 09:55 PM
84tamax's Avatar
Car: 1984 trans am
Engine: lg4
im having the exact same problem but i cant seem to figure it out the radio is out, the lighter is unplugged. what is on that circuit anyway?
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
GTAman
Mar 15, 2019 11:40 AM
Omega
Aug 10, 2015 12:46 PM
