Accidentally cut off the wires for the reverse lights, can another one be made??!!
Old Oct 15, 2004 | 04:40 PM
paulmoore's Avatar
Car: 1988 Camaro(92 Z28 clone)
Engine: Forged 383, AFR 195 419/430@wheels
Transmission: Monster 700R4 Yank 3600 stall
Axle/Gears: 9in Detroit locker-3.90's,35 spline
When I was trimming the wiring harness the other day, I never thought about it at all. As I was hooking up all the stuff to the T5 I realized that I cut the damn connector off for the reverse lights, and the wiring is cut allthe way up to the brake booster. Anyway, is it possible to make a homemade fix? Or should I just go to the junkyard and find a 5 speed car and take the connector and cut the wiring out and try to resplice it back onto the harness? Thanks for any replies to this thread, Paul Moore
Old Oct 16, 2004 | 03:30 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
If you still have the connector you can remove the pins from it and solder them to the existing wire. After that, push the pins back in the connector and plug it in.
PepBoys also carries a pretty large variety of OEM style connectors as well.
Jeremys87
Jul 14, 2022 09:08 PM
midge54
Sep 2, 2020 07:13 PM
Reddeath210
Oct 6, 2015 08:20 AM
Omega
Aug 10, 2015 12:46 PM
apie2546
Aug 8, 2015 07:12 AM
