Winter around the corner, need help wiring heater
Old Oct 25, 2004 | 04:38 PM
sleeper415's Avatar
Car: 1990 IROC-Z
Engine: carbureted 383
Hello and thank you in advance for the help, I greatly appreciate it. Winter is almost here and my 90 Iroc-Z has been converted to a 383 carbureted motor without a/c. Because none of the a/c electronics are hooked up, my blower does not work so I cannot even get the heater going. I've tried to find info on this and all ive found is that maybe I have to get an a/c delete blower, but is there any way to get mine to work? If not, can someone who has done the swap provide some insight into what i would have to do and where i can get a box? Again, thank you for taking the time to save me from the cold Missouri winter!
Old Oct 26, 2004 | 02:47 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Does the blower motor not work at all? If not, have you tried testing it?
Old Oct 26, 2004 | 05:31 PM
sleeper415's Avatar
Car: 1990 IROC-Z
the blower motor worked before the motor swap but now the controls dont turn it on or off, but im sure the motor is still good. I just assumed that all the a/c wiring that is now just loose wires has something to do with it.
Old Oct 27, 2004 | 06:52 AM
Wadebryant's Avatar
Might check the wiring splice connector to you fan. It's not easy to see from the topside but, it's located in the engine compartment between the motor and down behind the passenger side strut / inner wheel housing. These splices are sometimes disconnected when an engine swap happens. Did you also swap wiring harnesses?
Old Oct 27, 2004 | 02:05 PM
sleeper415's Avatar
Car: 1990 IROC-Z
I did not swap wiring harnesses, and I havent checked the connections you mentioned. I'll check them out and see whats going on there.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
Thornburg
Aug 25, 2015 01:46 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
