Defroster/Third-brake light connection
Old Nov 1, 2004 | 06:52 AM
gtaproject's Avatar
Car: 88 GTA
Engine: 305 LB9
I found the problem with my third brake light. The last "solder" point of the defrost wire pulled off the glass and prevented the third brake light from lighting. I have it attached with electric take, but want to re-connect it. I tried to solder it, but it wouldn't stay. Is there a specific solder to use, or some sort of "metal-glue" that will conduct the current and not melt when the wire heats up? This is literally the LAST issue with my restoration project. Probably not since this car rolled off the lot, has everything worked at the same time (hatch motor, headlight motors, digital dash, hatch struts, etc). I'm this close. Thanks for the help
Kevin
Old Nov 1, 2004 | 07:31 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
http://www.frostfighter.com/
BRoss99
Aug 10, 2025 05:08 PM
GTAman
Mar 15, 2019 11:40 AM
TheJoeY88
Dec 31, 2016 07:30 PM
DiabolicalRS
Aug 26, 2015 07:35 AM
Omega
Aug 10, 2015 12:46 PM
