aftermarket Tach, need to know what each wire is for.
Old Nov 2, 2004 | 12:31 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
hey guys i just bought an aftermarket autometer monster tach w/shift light that i am mounting in my dash. the shift light looks really pimp where the cigarette lighter used to be. anyway this tach has 4 wires, and i dont know for sure what each one does, below are my guesses, tell me if i am correct, thanks.
Red 12v ign only
Black ground
Green Tach signal from white wire on distributor
White 12v for light
is this correct?
Old Nov 2, 2004 | 12:41 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Red 12v ign only
Black ground
White 12v for light
for all autometer and auto gauge tachs:
red is ignition on power... (+12v)
black goes to ground
green is tach signal
white is for gauge lighting. connect to your dash lights if you want it to dim with the lights.
to make it work with a 4 cyl signal (for LS1s and 4cyl cars) clip both loops on the back and insulate them. to make it work on a V8, make sure both loops are connected. to make it work on a V6, you only clip one of the loops, but i dont remember wich one.
Old Nov 2, 2004 | 03:29 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
sweet i guessed correctly. thanks for the help
eightsixseven
Dec 16, 2024 01:50 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
mustangman65_79
Aug 7, 2015 09:41 PM
stalkier
Aug 7, 2015 04:49 AM
