2 questions
Old Nov 3, 2004 | 08:18 PM
1982z28's Avatar
Car: 1999 Z-28
Transmission: m6
Axle/Gears: stock/3.42
2 questions
1. I just purchased a 140 amp powermaster alternator. It says to upgrade the charge wire to at least a 8 gauge? Is this the wire that connects to the stud on the back of the alt. and does it go from there straight to the battery. Mine seems to disappear in a wire harness going back towards the firewall? Some insight on this would be appreciated
2. Will a tach out of a v-6 car work in a v-8 car? I know the oil sending unit is different btw the 2 (60 psi -v-8 80 psi v-6) I have been looking for one to replace mine at the local yards and all i have found is v-6. If it will work i need to replace the oil sending unit anyways.
Old Nov 4, 2004 | 01:04 AM
CEP89's Avatar
Car: 89' IROCZ
Engine: 5.7 L98
I got a tach from a v6 car and it works (the needle moves), but it's not accurate.
Old Nov 5, 2004 | 03:26 PM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
It is not neccessary to replace the wire since normal charging current is way below 140 amps. Typical output from a 140 will be between 35-50 amps normal driving. The chip in the tach has different jumpers for 6 vs 8 cyl engines. I'll try to pull the data and post how to change it.
Old Nov 5, 2004 | 06:09 PM
1982z28's Avatar
Car: 1999 Z-28
Transmission: m6
Thanks for the reply. I guess I can quit worrying about my wiring then. That alternator is fantastic. I dont have any problems now with the help of the cvr mini starter,optima red top batt.,powermaster 140 amp alt., and remote solenoid(which i pobably dont need any more)
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
