Dimming lights
Old Nov 11, 2004 | 09:33 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Dimming lights
I got an easy one for you, Sometimes When I pull up to a stop sign my lights would Dim, and then brighten. I thought it might be the Altinator, because my lights will Dim slightly when stopped at night. So I changed My Alt.
My lights seem Brighter, and it runs slightly better, BUT still every now and then my lights will Dim for a split second and then come back up...
My first thought is the Battery Connections, Is there anything else that could cause this, or I should check before I go looking???
John
Old Nov 11, 2004 | 11:43 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Check your grounds and the wiring. If it only happens when you are coming to a stop you might have a loose connection somewhere.
Old Nov 14, 2004 | 08:28 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Sometimes as you come to a stop & engine speed drops.The RPMs will drop a little too low & cause that.Check your idle speed as complete the stop.Or raise the idle speed slightly to see if that fixes your problem.
Old Nov 15, 2004 | 10:57 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I have the same problem, my idle is too low.
Old Nov 15, 2004 | 11:51 AM
okfoz's Avatar
... Actually it does not happen only when I am coming to a stop.. I fixed that much, my Alt was going out... But I have had it happen just driving down the road... If I get a chance I will tighten the connections I can find...
thanks
skeltor
Feb 2, 2016 10:37 AM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
luvofjah
Sep 3, 2015 07:08 PM
