Running Light
Old Dec 12, 2004 | 08:49 PM
DustyJL's Avatar
Car: 91 Camaro RS
Engine: 3.1L V6
Axle/Gears: Stock 3.23 open diff
Running Light
I want to make a running light in my car so whenever the engine is running the light is on. What wire would I need to tap into to make this work?
Old Dec 14, 2004 | 03:50 PM
Ozzy88GTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.0 TPI
Transmission: TH700-R4
Do you want it only when the engine is running or when the ignition is turned on?
Old Dec 14, 2004 | 04:59 PM
DustyJL's Avatar
Car: 91 Camaro RS
Engine: 3.1L V6
I want it only to turn on when the engine is running.
Old Dec 14, 2004 | 09:08 PM
Ozzy88GTA's Avatar
Engine: 5.0 TPI
You could tap into the fuel pump power wire at the relay. The pump is only on when the engine is running, or temporarily when the ignition is just turned on (engine off). With this make sure you use the signal from the relay to activate another relay for the lights so you do not put extra loading on the circuit.
Another one is from the A.I.R. diverter valve. I haven't checked it but I know that when the engine goes into closed loop the valve gets a sigal to divert air to the cat. This option would turn the lights on after the engine is in closed loop.
Ther might be other options out there too. Hope this helps,
-Ozzy
eightsixseven
Dec 16, 2024 01:50 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
Omega
Aug 10, 2015 12:46 PM
