Headlight doors w/fog lights
Old Jan 4, 2005 | 08:24 PM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
Did a search, couldn't find anything on this. For some reason I have a hard time believing I'm the only person with this problem.
When my fog light switch is on, if I turn on the parking lights, the headlight doors pop up but the lights are off. The same thing happens if I turn the parking lights on first, then turn on the fog lights. Any suggestions?
Old Jan 4, 2005 | 10:51 PM
GTAfanatic's Avatar
Car: 1988 GTA Black notchback
Engine: 1991 L98 355 TWIN Superchagred
Transmission: 700r4 shift kit 2500 stall
Axle/Gears: www.cardomain.com/id/gtafanatic
check if the wires behind the swick to see if they are melted or fused you are going to need to pull the wite harness out use a flathead. let me know how you make out
Old Jan 7, 2005 | 06:23 AM
92Transam's Avatar
Car: 91 firebird now
Transmission: 5 speed
I have the same problem I believe its a short in the switch because if I push the parking light button on very slowly it just turns on the parking lights and no head lights took me a little bit to figure it out but now I can always just turn on my parking lights and not pop up the headlights that are off lol
Old Jan 7, 2005 | 09:26 PM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
Let me give myself a big DUH Thanks, I totally forgot that the switch is designed with a feature to pop up the lights without turning on for maintenance, and the switch with a short would cause this undesirable effect. I won't have time till Monday but at least I won't waste time and I'll start with the switch.
Old Jan 10, 2005 | 10:25 PM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
Hmmm... I pulled the switch today and saw no problem in the immediate area with the wiring/harness. Oddly enough though its not acting up after I pulled out the switch. I had this prob when I first got the car and it disappeared. Being I'm not the only one I'll keep searching and keep you guys posted.
BRoss99
Aug 10, 2025 05:08 PM
DiabolicalRS
Aug 26, 2015 07:35 AM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
Omega
Aug 10, 2015 12:46 PM
