headlight problem..
headlight problem..
I got a 91 camaro and the headlights work fine but the brights only work when the tilt is all the way down.. Also my wipers dont work either.. Is it time for a new blinker, wiper, brights switch? My blinkers work perfect however... Or is it just a loose conection? Just dont want to be replacing parts that dont need to be..
Car: '91 Z28 & '90 RS Vert & '89 RS
Engine: 5.7L & none & 2.8L (soon to be LSX)
Transmission: yes
Axle/Gears: One's with teeeeefs
Is your steering wheel loose.....aka, if you pull down on it does it move? Mine did that. There is a thread around here somewhere that details tightening up the wheel assembly, which in turn straightens out all the other probs. Things get out of line and pinched and don't work.
