h4 headlight conversion
Old Jan 11, 2005 | 09:41 PM
slammed_z's Avatar
Car: 1985 camaro
Engine: 305 H.O
Transmission: auto
anybody know where to order these for are cars..i like the looks of these alot better so much more chrome lol but makes alot more lighting....btw anyone know the headlight size on are cars is it 4x6? also say angel eye ones..anyone head stuff about them?
Old Jan 12, 2005 | 02:24 AM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
I bought mine off ebay, it came with everything needed to do the install. But if you want to be able to use all 4 lights when you high-beam it, I would suggest buying a relay set. Summit sells a wiring harness that should take care of that. Anyways, search on ebay, and check out my cardomain in the sig, should give you an idea. For what its worth, I love mine
Will
Old Jan 12, 2005 | 05:58 AM
CrazyHawaiian's Avatar
Car: too many ...
And be sure to follow the tech article on properly wiring the car for H4.
Old Jan 12, 2005 | 06:40 AM
911rsq's Avatar
Car: '91 Z28 & '90 RS Vert & '89 RS
Engine: 5.7L & none & 2.8L (soon to be LSX)
Transmission: yes
Axle/Gears: One's with teeeeefs
They Look SUPER!!!!!
Old Jan 12, 2005 | 09:13 PM
slammed_z's Avatar
Car: 1985 camaro
Engine: 305 H.O
Transmission: auto
do we have to run a replay or something to use the high beams still..or is that only after you go over a certain bulb wattage?
Old Jan 12, 2005 | 09:14 PM
slammed_z's Avatar
Car: 1985 camaro
Engine: 305 H.O
Transmission: auto
*relay lol
Linson
Oct 24, 2025 02:00 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
