Need help, SES light comes on
Old Jan 19, 2005 | 07:18 AM
ace16a's Avatar
Car: 1985 Z28 Camaro
Engine: 5.0 TPI
Transmission: 700R-4
Axle/Gears: Posi Richmond 3.73
I've got a 1989 Trans Am with the 5.0 TBI motor. ever since i bought it, the check engine light comes on after driving 5-10 miles over 45 mph. I put an open element air cleaner on and moved the air temp sensor to the front of the car behind the drivers headlight. I've replaced the baro sensor, knock sensor and air temp sensor. When i check the computer, i get a code 32 and 43. any help is appreciated.
On another problem, my hatch release button doesn't work unless the key is in the off position and the brake light comes on when it is pushed. the release works, but the motor doesn't. Do i need a new motor?
One more thing, my fuel gauge only works from full tank to half tank. Do i need to put in a new pump or just find the right sending unit?
Thanks for any advise given.
Old Jan 19, 2005 | 08:51 AM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
Re: Need help, SES light comes on
The hatch release has a switch on the shifter that will only allow it to work in park and neutral.
There are several things that could be wrong with the pulldown motor assembly. They are notorious for breaking. Hawk's has replacement parts.
Old Jan 20, 2005 | 08:12 AM
ace16a's Avatar
Engine: 5.0 TPI
The switch on the shifter works fine, the car needs to be turned off in order for the release switch on the dash to work.
skeltor
Feb 2, 2016 10:37 AM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
luvofjah
Sep 3, 2015 07:08 PM
