Fuel Guage
Old Feb 25, 2005 | 08:14 AM
Silver_Panther's Avatar
Car: 1982 Z28 & 1987 Z28
Engine: Carbed 400ci & TPI 305ci
Transmission: TH-200C & TH-700R4
Fuel Guage
Alright.. The car has been doin this to me for a while now. it's a 1982 Camaro Z28. And every once in a while both the voltage guage and the fuel guage will quit working at the same time. All other guages work and no fuses are blown. Never do they quit working independently but always both quit at the exact same time. Anyone know where the most likely place to look for a short or how to track down this problem?
Thanks,
Matt
Old Feb 25, 2005 | 02:35 PM
69-er's Avatar
I'm going to base this on an 83 Camaro, assuming they are wired the same. There is one pink/black wire that powers these two guages, but it also goes to the tach, oil pressure gauge and the choke light. Since those are still working, I can only guess the common point to this problem might be a bad ground inside the instrument cluster.
Larry
Old Feb 25, 2005 | 04:30 PM
thanks.. that was kind of my guess.. Looks like i'm gonna have to be tearin the damn thing out once again.
Old Feb 27, 2005 | 03:33 PM
Ended up being the Paper thin circuitry on the back of the cluster. I guess the copper was split or sumthing not makin a connection all the way to the 2 guage connections.
Luckily I had a spare cluster in the garage that I pulled froma junkyard last year. Transfered my guages to that housing, put it in, and everythings great now.
I'll probably solder in a jumper wire from the good side to the bad side of my old cluster.. And keep it for a spare.
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
355sbcTPI
Aug 19, 2015 04:38 PM
92camaroJoe
Aug 13, 2015 06:07 AM
