Msd box location and wiring
Old Feb 27, 2005 | 11:04 PM
RacerDonnie13's Avatar
Car: 1988 Camaro SC
Engine: 383 Stroker
Transmission: TH-350
Just got my MSD 6AL box today and was wondering wheres a good place to mount it? Ide like to see some pics of where yall mount yours. Also where is a good place to run the red wire to make it cut on when I turn the key.
Old Feb 28, 2005 | 08:50 AM
WILL85IROC's Avatar
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
u might wanna try a search, there was a thread on this about 3 weeks... with some good pics also...
Old Mar 2, 2005 | 01:17 AM
Tony89's Avatar
Car: 1989 IROC-Z Convertible
Transmission: Art Carr 700-R4
msd location
I tried something a little bit different. I may get attacked for doing it this way, and it was no picnic putting it here, but here goes. I put it below the air boxes in front of the radiator. It's just behind that weird support that holds up the area where the hood latch is. I attached it to one of those L-brackets that you can buy from Summit. I attached the small part to a piece of wood on the bumper bar. You can only see it if you look in the latch hole. It will fit, but it's tight. Also, the one I put in is a 6AL-BTM because I have a Vortech. This one is about 1/2 inch wider than a regular 6AL, so if yours is a regular one, you'll have even more space. I figured that this would be the coolest place to put it and be outside the cockpit. Mounting one of these things under the hood is popular, but MSD instructs buyers to be mindful of underhood heat. So, in my paranoid mind, I figured I'd just take my time, and try to find the best possible place. I hope this helps you.
BRoss99
Aug 10, 2025 05:08 PM
9192camaro
16
Feb 3, 2019 12:21 AM
midias
Aug 15, 2015 05:07 PM
marcusaw
Aug 10, 2015 08:13 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
