Make power windows work in accessory too
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
Has anyone done this? I can't see that it would be that hard. Add an extra wire probably. The only problem I usually run into with the fuse box is you can't pull it down very far. If anyone has done this or has any encouraging (or discouraging) comments, I'd like to hear them.
On a side note, why doesn't the search highlight the search words in red anymore?
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It probably wouldn't be that hard to do. BTW, the fuse block can be dropped further by removing the two screws at the aft edge of it at the hinge.
I've removed the two screws, but I still can't get it very far down because the wires won't allow it.
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
