Dual Coil Connectors
Old Mar 7, 2005 | 11:31 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
I'm trying to build an adapter harness without butchering the stock ignition.
I found a listing in a DIY-EFI doc that has part numbers but does not say who's numbers.
"Coil connectors
The remote coil HEI (small cap) has two low voltage connectors. The black one has the tach signal, the grey one has the large power lead.
Black: S-563
Grey: S-562 "
Does anyone know the part number or where to buy the two connectiors for the remote dual connector coil?
(With or without pigtails)
I also need to confirm the two pin connector going to the dizzy.
This is an 8 pin module (C and +) are the pins from the coil.
I found that it might be GM p/n 15306195.
TIA,
JP
Old Mar 7, 2005 | 12:44 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
GM doesn't sell the individual connectors anymore or at least that is what I have been told by my local dealership. They do have pigtails that you might be able to get. If that fails, your best recourse is to go to a junk yard and get some there.
Old Mar 7, 2005 | 07:18 PM
89Formula5.7's Avatar
Car: 89 Formula 350
Engine: L98 w/ Stealthram
Axle/Gears: 9 bolt 3.27
Or check Year One.
Old Mar 7, 2005 | 09:25 PM
JP86SS's Avatar
Thanks,
I found a place that makes them called "Car-Pak" in Michigan and "PICO" in Canada but can't find any distributor information on either of them.
The catalogs have anything you could want as far as pigtail replacement connectors.
If I find souces I'll post them up for others to use.
Jp
edit: Found info on this page (see section 9, lots of goodies)
http://www.autobodysupplies.com/
I called Car-Pak and asked for distributor, he said this place is the only one hosting the catalogs.
Waiting for quote back on cost/delivery from e-mail.
Nick McCardle
Sep 10, 2015 08:36 PM
Djmathis123
Sep 8, 2015 08:42 PM
Jlanz55
Sep 6, 2015 03:05 PM
scotrans am
Sep 5, 2015 04:26 AM
