Starrrter ??????
Old Mar 25, 2005 | 11:16 AM
84RIceEater's Avatar
Car: 84 Camaro. 90 integra
Engine: LG4, 1.6 (402hp)
Transmission: 700r4, JDM ITR w/ kaaz LSD
Starrrter ??????
whats the symtoms of a starter going out? i tryed to start my car and it didn't try to crank and of coruse all the insturment panel lights came on and it was "Buzzing".I had just replaced my starter... and my igniation switch.on tuesday it did the same thing.. and i poped the hood and banged on the starter and it turned over, and fine the rest of the week.(intell now).i did it today and nothing.Some thing tells me in installed the ignaition switch wrong. but i never had this problem.SO the other thing....... If i installed the switch wrong and it has power going to it some times constint.(radio,Window Wipers,heater etc.) then it draided all my battery??? i dunno. Thanks
i just installed a **** kid and i checked the netural safty switch and its all good.
Old Mar 27, 2005 | 09:53 AM
Vader's Avatar
Verify that teh fusible link connections and positive power connection at the starter are intact. Check the fusible links for continuity.
You may actually haev a problem with the ignition switch linkage / switch position adjustment instead of the switch itself.
