Has any one made a custom switch to raise & lower headlights?
Old Mar 28, 2005 | 12:30 PM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
Im tired of cranking my headlights down i was just wondering if anyone has rigged a switch to control the opening and closing of theyre lights.
Old Mar 28, 2005 | 02:45 PM
Cyfun's Avatar
Car: '83 Trans Am, Black on Red
Engine: LG4 305ci V8 w/ CCC-Qjet
Transmission: Rebuilt 700r4
Axle/Gears: 4th gen 2.37 posi w/disc brakes
I think GM made one, and installed it in all of their Firebirds.
Seriously, dude, you're not making any sense.
Old Mar 28, 2005 | 03:01 PM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
Sorry to be uninformative,my headlights turn on and off properly, they go up when turned on but not down when turned off. I dug into it a little bit and havent been able to pinpoint the problem. So i was simply asking if anyone had custom wired a switch to control the headlights opening and closing.
Old Mar 28, 2005 | 04:11 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Are you using the switch right? Push the bottom right corner down hard and hold it until they go down.
Old Mar 28, 2005 | 04:17 PM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
Ya ive tried that, ive had the car a couple years and they havent ever worked properly
Old Mar 28, 2005 | 09:02 PM
BruceEmbry's Avatar
Car: 82 Ponitac Firebird
Transmission: 4L60e/TCI TCU
Hi,
I had the same problem a few years ago. This problem can be caused by defective headlight switch. There are also some relays up near the headlights. I would inspect the wiring up at the ralays and headlights. If the wiring is OK, replace the headlight switch on the dash.
Old Mar 28, 2005 | 09:09 PM
Cyfun's Avatar
Ok, I get it. Yeah, check the wiring for the relays and motors up front (for starters, just unplug and plug everything). If that doesn't help, you can easily take the instrument panel bezel off and remove the switch. I had a similar problem and was able to repair the switch by tweaking the copper contacts, but you can always just get another one from a junk yard.
Anyone have the wiring diagram for Firebird headlights?
Old Mar 29, 2005 | 08:56 AM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
If i am remembering correctly i believe the 89 set up is different than the prior years, the relay is near the firewall. I just havent found a donor car to swap parts to check things.
Old Mar 29, 2005 | 09:25 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
1987-92 use the same two-wire headlight actuator and headlight control relay (mounted to the firewall). I picked up a few of the relays the PAP on my last trip. I need to clean and test them, then I'll be adding them to my web site. New they run around $150, OUCH! There was a prior thread on this site where somone opened one up and rebuilt it.
Lon
Old Mar 29, 2005 | 09:47 AM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
150.00 wow!!, i was just offered one for 10.00 i guessi ll scoop it up.
Old Mar 29, 2005 | 09:57 AM
lonsal's Avatar
New, don't hesitate and grab it for $10. It has "GUIDE" in raised letters on the upper right corner of the case.
Lon
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
The_Phoenix
Feb 4, 2016 07:10 AM
kah992
Aug 19, 2015 02:55 PM
