HEI ignition coil
Old Mar 31, 2005 | 03:26 PM
dahlman's Avatar
HEI ignition coil
Hi, i'am use to coils that only have + and -.
On my friends camaro (HEI with external coil) it seems to be 4 connections. Why so many connection and how do i know wich to use? (We don't use any original wire harness)
Please help me out.
/Peter
Old Apr 5, 2005 | 04:46 PM
dahlman's Avatar
Anyone?
I've checked the Chilton manual but have'nt found the answer, can't really be that complicated?
Old Apr 6, 2005 | 08:50 PM
hot91t/a's Avatar
Car: 1991 Trans Am
Engine: built 305 carbed
Transmission: built 700R4
HEI distributors are stand alone, there should be a small wiring harness on it to connect to the cap, all u need is a hot wire to feed the battery connection and a wire that connects to ur tach
Old Apr 7, 2005 | 07:52 AM
dahlman's Avatar
Yes, but we are not using any of the original wiring harness...
I guess it would work with a batteri + and ignition module output "Trigger" for ground?
Old Apr 7, 2005 | 08:02 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Tjena....
Look at this MSD install http://www.msdignition.com/pdf/6%20series/6series.pdf
/N.
Old Apr 7, 2005 | 08:55 AM
dahlman's Avatar
Ah, simple as i thought!
Tack som fan/Thank's alot!
RedLeader289
May 28, 2019 01:47 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
skinny z
Oct 5, 2015 06:23 PM
Damon
Sep 26, 2015 04:29 PM
RedLeader289
Sep 23, 2015 06:50 AM
