speed sensor
Old Apr 5, 2005 | 11:38 AM
Scamo-2.8's Avatar
Car: 1989 Camaro RS
Engine: 1990 - 5.7
Transmission: Tremec 3550
Axle/Gears: 9 Bolt - 3:45
speed sensor
Can someone tell me how the speed sensor affects the performance of the car? Will it be a problem if it's not hooked up?
Old Apr 5, 2005 | 03:38 PM
camaro05's Avatar
Car: 91 Z28
Transmission: built 700R4
your cars speedometer won't work if it isn't hooked up.
Old Apr 5, 2005 | 08:52 PM
Scamo-2.8's Avatar
Car: 1989 Camaro RS
Engine: 1990 - 5.7
With a 90 to 92, yes that is correct because the speed sensor is electronic. However the speed sensor on 89 and older is cable driven with the optical speed sensor behind the gauge cluster.
Old Apr 5, 2005 | 08:55 PM
Scamo-2.8's Avatar
Car: 1989 Camaro RS
Engine: 1990 - 5.7
Or does anyone know if the optical speed sensor sends the same signal as the electronic?
Old Apr 5, 2005 | 09:15 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
The optical sensor from what I've read is infra-red that is attached to the instrument cluster. The electronic one is gear driven in the tranny.
Old Apr 6, 2005 | 11:33 AM
Scamo-2.8's Avatar
Car: 1989 Camaro RS
Engine: 1990 - 5.7
Right I understand that, but do they send the same signal to the computer? As in voltage or whatever?
Eric2ndGen
Nov 5, 2015 01:51 PM
angel2794
Sep 8, 2015 06:22 PM
IROCtometal
Sep 2, 2015 02:01 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
