auto-power down windows????
Old Apr 21, 2005 | 04:56 PM
WILL85IROC's Avatar
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
in my 04' durango, and many other newer cars, the drivers side window has an auto-down power window switch built into the regular switch.... u hold the switch until u get your desired window position or u can press it until it clicks and the window goes all the way down without u having to press the switch continually... has anyone ever done this for their 3rd gen? if so, how? i was gonna go thru the junk yard and look for some parts from a newer car and try and use it my iroc...
Old Apr 21, 2005 | 06:26 PM
Bunker82's Avatar
Car: '82 Camaro
Engine: 383
Transmission: TH-350
From reading other posts, it seems that some Saturn switches have the capability built in. But they will not fit into a 3rdgen console though. If you wanted to do some custom work, it might work. I am going to get a DEI 530T module that allows you to use your stock switches and get the one touch up and down.
Old Apr 21, 2005 | 06:30 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
(the dei) where r u buying it from? and for the saturan, do i have to grab all the wires and relays, etc.....????
Old Apr 21, 2005 | 11:08 PM
Bunker82's Avatar
Car: '82 Camaro
Engine: 383
Here is one place to get the DEI module. The lowest prices I have found for them is on eBay, so that is likely where I'll get it. Runs close to $60.
For the Saturn switches, do a search. You should find more info and decide if you want to go that route. If I remember though, the one touch down was only for the driver's side.
Old Apr 22, 2005 | 08:04 AM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
THANKS ALOT!!!! THAT LOOKS GREAT 2 ME!
Fireslash
Apr 11, 2016 06:43 PM
jrdturbo
Mar 31, 2016 02:58 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
kkirch15
Sep 30, 2015 04:44 PM
