speedo gauge cluster , some gauges not working can you help?
Old Apr 24, 2005 | 05:43 PM
JD1990camaroRS's Avatar
Car: 1990 Chevy Camaro RS
Engine: 3.1 soon to be 305 or 350
Transmission: auto 700R4
my fuel gauge does not work, tach does not work, and oil pressure does not work, i have a 90 rs w/ 115 mph yellow speedo cluster 3.1 and 700r4, although speedo, engine temp and volts work
Old Apr 26, 2005 | 11:13 AM
ttt
Old Apr 28, 2005 | 11:25 AM
Black_Widdow's Avatar
Car: 05 GTO, 88 GTA, 98 SS
Take out the gauge cluster and put it back in. Sometimes the cluster will not be bolted/screwed in tight enough and things wont work.
If that doesn't fix the problem, check the resistance in the printed circuit on the back of the cluster.
Old Apr 28, 2005 | 11:37 AM
what is the resistance?????
also i am going to pull it out right now and put it back in , will post back in 10 minutes
Old Apr 28, 2005 | 02:24 PM
ok, it was bolted in all the way, took it out and put back in, still no good, checked to make sure it was connecting right, the tach jumped left and right when i put the cluster in place and pulled it back, does that mean anything?
Old May 6, 2005 | 11:58 AM
macdadyZ28's Avatar
Car: 87 Formula
Engine: '00 LM7
Transmission: 4L60e
Axle/Gears: 3.23 posi
the tach, oil and voltmeter are on the same fuse if i remember correctly.. did you check the fuse box to see if it burned out. I remember the same thing happened when i frist got my 82....
Old May 10, 2005 | 09:27 PM
KahliFornyaKing's Avatar
Car: 1992 RS Camaro
Engine: 305 TBI
speedo not working
is the speedo on its own fuse or is it driven by a cable cause mine is notworking at all? I have a 25th anniversary rs if that makes any difference
Thanks.
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
fonzie85
Aug 13, 2015 11:50 AM
ChevyZ71
Aug 13, 2015 07:30 AM
