87 TPI Fuel Question
Car: '91 TA vert
Engine: turboLSx
Do 87 TPI cars have the oil pressure activated fuel cutoff? Where's it located? What does the connector look like? TIA
Car: 1989 Iroc-Z
Engine: 5.7L TPI
They don't have a fuel cut-off, what it does is to keep the fuel pump operating in the event of the fuel pump relay failing. It will also send a signal to the fuel pump at start-up after 4 psi of oil pressure has been built up if the relay fails. It is located above the oil filter on the drivers side.
beachrodder
Aug 25, 2015 08:05 AM
R3500
Aug 17, 2015 12:16 PM
Sanjay
Aug 12, 2015 03:41 PM
