Speed limiter needs to go.
Old May 3, 2005 | 02:05 AM
odddoylerules's Avatar
Car: 1992 rs 355 TBI **swapped**
Engine: 80 Ford Fiesta GHIA dual carb
Transmission: 72 Cutlass S 350/350 3.42
Axle/Gears: s10 tq converter/stock rear gear
115 just isnt fast enough now that the rs sports a 350. How can I disable my vehicle speed sensor for track days? I have better than stock tires so I assume its safe to go faster. Can I just switch the vehicle speed sensor to make it not work? I dont care if I lose my speedo, as long as I have a working tach.
you can run a rebuilt vehicle that hasnt passed the WSP inspection right?
Old May 3, 2005 | 11:26 AM
dyeager535's Avatar
Car: Which one?
Engine: 355
Transmission: 465
If there's a speed limiter in your setup, I'm guessing thats in the PROM. Vehicle Speed Sensor just tells the ECM how fast the vehicle is going, it doesn't limit you itself. It's used for a few things. Doing a search on speed limiter through the forums should answer how that limiting function is handled.
Are you trailering the car to the track or not? Just getting an idea on the WSP comment. I know a couple of years back they stopped requiring an inspection for out of state vehicles being licensed in thist state, but I doubt that influenced the "rebuilt" portion of the requirements. This is to title/register the vehicle of course.
When I "built" my truck, the state required a WSP inspection, which gets you a new VIN. They wanted receipts for everything...frame, body, doors, engine, transmission, tailgate, etc. Every large piece on it.
Old May 3, 2005 | 03:25 PM
reciepts for everything? What all does EVERYTHING include?
adelane
Sep 9, 2015 08:51 PM
Eric-86sc
Sep 7, 2015 02:10 PM
SG91camaro
Sep 5, 2015 10:27 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
