Carb Swap Fans/Fuel Pump Switches
Old May 11, 2005 | 03:56 PM
Kevs87Z28's Avatar
Car: Yellow/Black 1987 Z28
Engine: 355 Carb
hey guys. i wired up some switches for this carb swap im doing tomorrow. i wired a fuel pump switch, fan switch, and have another switch for tcc when i get around to hooking it up.
well the problem is when i switch on the fuel pump switch i can hear it turn on then when i turn on the fan switch the fuel pump shuts off even with the switch on. and if i leave the fuel pump switch on and turn the fan switch off the fans keep running even with the fan switch on. so here let me lay that out...
Fuel switch on - pump on
fan switch on - pump turns off fans come on
fan switch off fuel switch on - fans run no pump
fan switch on fuel switch off - fans run
so if i turn the fans on the fuel pump shuts off is pretty much what i am saying. and when you turn the fan switch off and have the fuel switch on the fuel pump doesnt come back on but the fans stay running. any ideas?
Old May 11, 2005 | 05:08 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Re: Carb Swap Fans/Fuel Pump Switches
Originally posted by Kevs87Z28
any ideas?
You have something wired wrong
How about posting up a diagram of what you have done?
theshackle
Mar 5, 2017 06:37 PM
midge54
Jan 29, 2017 07:00 PM
Dkelz313
Apr 7, 2016 10:38 PM
86IROC112
Aug 17, 2015 02:00 PM
cstrobel65
Aug 15, 2015 10:19 AM
